Текущее время: 14.07.2026 12:25
 Заголовок сообщения: Предохранитель ABS
СообщениеДобавлено: 27.08.2004 19:25
Машина - Мерин 124 220E
Помогите из приложенного списка найти предохранитель ABS :roll:
1. cigar lighter, switch beatable rear window, glove compartment light, rear wipe/wash system (ortho. back rest, folding head restraints/rear compartment, radio)
2. wipe/wash system, optical horn (relay headlamp cleaning unit term. 86, relay comfort circuitry term. 86)
3. parking/tail light right, warning buzzer, illumination: license plate, instrument ,control elements (headlamp cleaning unit)
4. fog light, rear fog light
5. stop lamp, instrument, front roof light, electric bulb control unit (cruise control, tachometer, trailer control unit)
6. turn signal lamp, horn (outside temperature gauge)
7. back-up lamp, heating water valve, water pump, engine fan, heating system for washer jets climate control system (relay auxiliary fan term.86, aut. transmission electrics, switch-over valve ignition change-over, air condition compressor *)
8. parking/tail light left
9. diagnostic term.6, hazard warning system, clock, front roof light (electronic radio, vanity mirror light, relay comfort circuitry term.86)
10. beatable rear window
11. intake manifold heater (gearbox oil cooler)
12. blower motor **
13. low beam left
14. low beam right
15. high beam left
16. high beam right, high beam indicator
A. (sliding roof) (window lift middle *)
B. safety belt handover arm, adjustable, heated outside mirrors (rear heater, roller sun visor)
C. rear roof light, trunk light, rear door locking system, safety belt handover arm, seat back arrester (central locking system, door lights, reading lamps, aut. antenna.)
D. (auxiliary fan)
E. (front seat adjustment, jacket tube adjustment-memory)
F. (front seat adjustment, jacket tube adjustment)
G. (window lift front)
H. (window lift rear)
** with automatic climate control: fuse outside fuse box outside fuse box: seat heating front, trailer coupling
Заранее сенькс :wink:
СообщениеДобавлено: 28.08.2004 12:24
извини промтом переводил:
1. сигара легче, переключите побиваемое тыловое окно, свет купе перчатки, тыл вытирает/вымоется систему (ortho., назад отдыхают, сворачивая главное купе ограничений/тыла, радио)
2. вытереть/вымойтесь систему, оптический рожок (реле headlamp убирающий срок{термин} единицы. 86, реле успокаивает срок{термин} схемы. 86)
3. право света стоянки/хвоста, предупреждая гудок, освещение: пластина лицензии, инструмент, управляет элементами (headlamp убирающая единица)
4. туман легкий, тыловой свет тумана
5. остановить лампу, инструмент, передняя крыша легкий, электрический блок управления сосуда{луковицы} (контроль{управление} круиза, тахометр, блок управления трейлера)
6. лампа сигнала поворота, рожок (вне температурного шаблона)
7. лампа дублера, нагревая водный клапан, водный насос, машинного болельщика, система нагрева для системы управления климата реактивных самолетов мойщика (реле вспомогательный срок{термин} 86 болельщика, передача автоморфизма electrics, выключатель - по замене воспламенения клапана, воздушный компрессор условия{состояния} *)
8. свет стоянки/хвоста уехал
9. диагностический срок{термин} 6, система предупреждения опасности, часы, передний свет крыши (электронное радио, свет зеркала тщеславия, реле успокаивает срок{термин} 86 схемы)
10. побиваемое тыловое окно
11. нагреватель коллектора потребления (холодильник нефти{масла} коробки передач)
12. двигатель трубача **
13. низко луч уехал
14. низко право луча
15. высоко луч уехал
16. высоко правильный луч, высоко сияйте индикатор
A. (скользящая крыша) (окно снимает{поднимает} середину *)
B. рука передачи привязного ремня, приспосабливаемые, горячие внешние зеркала (поднимает нагреватель, щеток солнца ролика)
C. тыловой свет крыши, легкий ствол{магистраль}, поднимает систему захвата двери, руку передачи привязного ремня, место обратный разрядник (центральная система захвата, огни двери, настольные лампы, антенна автоморфизма.)
D. (вспомогательный болельщик)
E. (фронт помещает регулирование, память регулирования трубы жакета)
F. (фронт помещает регулирование, регулирование трубы жакета)
G. (окно снимает{поднимает} фронт)
H. (окно снимает{поднимает} тыл)
** с автоматическим контролем{управлением} климата: соединитесь вне блока предохранителей вне блока предохранителей: место, нагревающее фронт, сцепление трейлера
СообщениеДобавлено: 31.08.2004 9:52
У меня промт то же выдает ...
А где искомый пред - ХЕЗ.
Неужто нет его :roll:
СообщениеДобавлено: 31.08.2004 11:56
Такого предохранителя в списке нет.
СообщениеДобавлено: 31.08.2004 15:16
Но ABS стоит на машине и причём глючит :!:
Может тогда подскажешь как его срубить безболезненно для себя и авто :?: :?: :?:
Напоминаю машина МБ 124 220Е
СообщениеДобавлено: 31.08.2004 15:30
а почему бы не поискать его в районе блока абс
СообщениеДобавлено: 31.08.2004 15:38
посмотрим в эту сторону ....
